free website stats program 2007 Maintenance Specs. | Page 2 | Harley Davidson Forums
Which defective diaphragm are you referring to here? Is it the one in the top of the carb? If so the engine will surge from a leak here, like hunt and peck trying to find a comfortable mixture.
Glider:I think that your thoughts re intake leak may be right on the money. We discovered a long, almost circular, hairline crack on the horn side manifold where it went into the rear cylinder.It is being welded as we speak; am hoping sounds all gone when we re-install it and start up!!
You really need a Fixture to hold the intake in aliment before you start welding on it. If not it will warp and still not seal. I personally would have trashed the broken one and replaced it with a new one and use Comtec gaskets at reassembly, they allow more flex between the Heads and Intake.
Glider: I was referring to the diaphragm in the petcock which, as I understand, H-d is recalling and replacing?
