RibEye
Senior Member
Just an alternate thought:
A fuel injector wire that is broken inside the insulation could contribute, if not cause, your symptoms. I have seen bad crimps on the connector to an injector that caused intermittent connection, without throwing an injector code. Why it happens when hot is accounted for by the insulation softening and allowing a slight shift in conductor alignment. This problem would worsen at idle, since there is all kinds of jumping around. A good continuity and wiggle test would exclude this possibility.
Enjoy,
Rich P
Enjoy,
Rich P
