free website stats program 2009 Model Year Update Bulletin | Page 2 | Harley Davidson Forums
Status
Not open for further replies.
NOW I WONDER WHAT MINE IS?
I JUST HAVE TO WAIT AND TRY TO PUT AT THE BACK OF MY MIND ...... unless i use this as an EXCUSE to tear into the motor and check.....
09/FLHR
Actually from what I have read & seen, it is not too bad a job to check. You can do it from the oil pump side of the crank leaving almost everything intact. I have not checked mine, but if I started feeling vibration I would. There is a video on U-tube (I think) where there is a guy showing excessive runout using a dial indicator at the oil pump. There are also some Great video's at Performance Revolution's website where Brian goes into Great detail about it.
Checking for runout with the crank in the engine is a MUST. You can Not use a truing stand with 2 live centers to check the crank, even if you have it out of the engine! You Must support the crank from the bearing surfaces...
Hoop!
Status
