Composite tire by definition implies complexity of different natural and manmade materials. That said, virtually all tires use composite compounds in the rubber tread, it is a petrol product basically with exotic belts and bias/radial plies, be they aramid, carbon fiber, steel, polyester, rayon or nylon. Only the maker' production and R&D team know for sure, but todays tires are trully the product of many many hours and labor. I am surprised that when all boils down, the performance crowd gets maybe 5k out of their rears, tourers get 12k out of theirs and the ocasional easy rider can squeeze bout 15k, but usually a road hazard, wear problem, compound degradation (cuts or cupping) end it earlier than it should. Usually change 2 rears for every front, but let your experience be your guide...mileage is just a number, and if you had your tires on more than 5 years, change'em anyway if there is evidence of cracking or the date code tells you the mileage is not reflecting their useful life. UV and ozone degradation is why the tires turn brown rather than black...and your putting tire dressing on 'em or tire black does not mean the business end is still good.
Just keep an eye on the inflation pressure, if over the life of the tire it is worn in the center and edges are fine, lower average pressure 3 lbs or so the next time, or you just are a long distance straight up rider...no harm no foul. If yours are worn on the edges and the center has tread you have been running underinflated and may want to raise average pressure 3 lbs or so or you have been corrnering a lot, again kudos for a job well done if you are close to even and got the smiles per mile out of it. Enjoy the ride...it gets better as the mileage piles on and you are extracting the best those tires have to offer...(your bike if it could is smiling as should you).
