billyd1
i have a 2010 flhtk limited with 113 and i use the heat management and roll off the throttle to deactivate the cruse with no problem. only problem i have had is rolling throttle at start, just barley touching throttle at start makes it idle to fast and have to cycle the the switch to reset. i just dont touch it anymore when i hit the start button. now if i can get the thing to keep belts on it. ripped the teeth off of 2 belt. gonna convert to chain drive. good luck.i would think that if it through a code it should be in the code history
I hope Hobbit doesn't see this or there's gonna be some engine work on his CVO before it's even broken in!! :lolrolling
