I agree. Venting is the only logical explination that makes any kind of sense due to the engine running perfectly. I'm just trying to figure out "why" all of a sudden... I haven't changed the tune or timing what so ever. One would think if it was running rich it would level off a bit with the cooler ambient temps in my area cause it's the same tune I ran in 80 degree temps...
One question I do have?. I understand a richer tune is needed for cooler, more dense air and the ECU will adjust. Could the tune I'm currently running be a bit rich being the engine is not getting as HOT because of the cooler ambient temps?
Reason I ask is a hotter engine will evaporate fuel quicker and the raw smell would not be as excessive. :eam
I don't know what your running for a tune but these beasts need to run a little richer as they run to lean stock. How do your plugs look? What's the color of the exhaust tips? Are you getting a little pop once in a while through your exhaust on decel. Those 3 things might tell you if your running a little too rich.
