dolt
Well-Known Member
I would think with a stage 4 kit, the 259E cams, 10:1 higher compression pistions, Polished and ported heads, 58m throttle body, high flow air cleaner, fullsac DX pipe and SE tuner, I would think this should be closer to 118hp and 118TQ or at least close..
I assume the kit is the 92500011 kit since for the 103CI motor. Why would you expect more than what is advertised for the Stage IV kit? You are fortunate to achieve the advertised TQ/HP; kudos to your tuner. I know guys that have had the dealer install and tune both the Stage IV 103 kits and did not achieve the advertised TQ/HP. What is missing from this kit and the "race" kit is the high flow injectors and the intake manifold. You might see 115 numbers with a cam change, better exhaust and tune.
Hillybilly is wrong about the HD advertised HP/TQ numbers. Those are not flywheel numbers but rear wheel numbers. Very clearly indicated as such in the SE Performance catalog dyno sheets.
