If your adding a tuner then I'd say yes you should run it on a dyno, but with the mods. you have now and adding only a fueler a dyno would not be necessary. JMHO.The tuner will change with the dyno tune. Just hope that makes some difference.
What is a fueler?
Theres several on the market, you can read about them on the forum here. They are a plug and play to your injectors and add more fuel to the engine. Harleys run to lean from the factory so to conform to emissions standards. Adding more gas will make your ride run cooler and run better.What is a fueler?
