Gym?! Careful, using dirty words here gets you reportedFYI, lithium batteries are great until they die.No warning of failure,just dead.Could happen anywhere, anytime.My Son had one on His 2012 Classic.Only lasted 2 years,then dead without warning.I will stick with the AGM battery.Lose the weight at the gym!
Just make sure your doing the load test on a fully charged battery.
In my opinion after a couple load tests with minimal drop on the meter your good to go.
Having said that I just reread your post and I see your scoot is a 2017, it may be time for a new battery. Give the Load test a whirl and see what you think.
Not sure if this will help.
iThere are 2 relays in the fuse panel box IIRC. 1 starter, 1 system relay. They should have the same P/N on them. Just reverse them to see if starter works. There may be a 3rd. but I think it has a different P/N.
Do you have the manual for your scoot? Check all the fuzes and relays, may have a week or bad one.
