jamesearl
Well-Known Member
Holy cow.Didn't you say it was the 1st time you were getting an extended warranty? Yeah redline hadda be someone else.You have Me mixed up with someone else.I use Formula plus.I was concerned with using any thing else, because it would mix with the Formula plus in the primary.Been in the shop for a month.Mostly waiting for extended warranty to authorize $3000 repair.Parts should arrive this week.They are replacing the gear set worth $2000.
[QUOTE="Harttoo]I have the transfer issue.First noticed at 10000 miles.Gear grinding while shifting.24,000 on her now and third gear stripped.In the shop right now for rebuild.
Assume they are going to fix the migration issue as well?? $25 seal. Make sure they do this and refer to the tech bulletin; don't have the number.[/QUOTE]
You'd think they had to,no? Isn't the migration thing trans migrating to primary?So you get an overfilled primary,and not enough in the trans to bathe the gears?
