J
Jack Klarich
Guest
I used a multimeter in the diode function to check them and they bench check ok. if I hook a cheap analog volt meter like in a car to the battery and run the bike will I see a the needle jump around if the diode is bad?
Probably not, a diode is a one way switch so to speak, in automotive field they can be bad and still show enough voltage to fool you, but under charge or kill a battery
