W
		wildspirit97
Guest
Start with taking a look at the Primary cam chain tensinoner. If it looks good, you only spent 7 bucks on a cam cover gasket. If not pull the outer cam and crank gears and take a close look at the bushing for the pinion shaft in the cam support plate. I could see a pretty good gap between the bushing and the shaft on mine. I'm not sure if enough of there pinion shaft sticks out past the cam support plate to get measurement, but the H-D tech told me it's supposed to be checked with the support plate on. I don't buy it but that's what he said.I can't check the run out but I can still inspect the tensioners....right? If they are good I won't worry about the run out.
Keep in mind that I've had problems from early on with my Primary chain auto tensioner over tightening and my compensator kept coming loose, so I imagine those are also symptoms of bad crank run out also. After this I probably won't wait too long to open up the new motor and check run out. I have the quick install push rods sitting in my garage now since I didn't have to use them because there was no point in putting anything back together..
