G globalwheels Member Sep 23, 2009 #11 :small3d007: I think piston fit in cylinder is .0020-.0025 always double check.
TQuentin1 Well-Known Member Staff member Moderator Sep 23, 2009 #12 usa68 said: I am building a 1974 FLH with the original 74" engine new V Twin crank, I am using V Twin replacement piston's .040 over, what should the piston to wall clearance be set at. Click to expand... I assume you found what you needed by now, but if anyone else is in the same boat, here are the engine specs for the Shovels. TQ Attachments Engine specs from shovel_manual_66-84.pdf 172.5 KB · Views: 8
