Frenchie
Do you still have the old clutch pack? If so take a measurement of the fiber plate hole diameter and compare that to the new fiber plate hole. Remember that when you are sliding the new filter plates in and checking them for not binding that there is not centrifugal side load on them as opposed to when the bike is running and any slight binding can be amplified when bike is running. Also when you have the clutch pack out get s small straight edge ruler and double check the studs to ensure that they are true and not tweaked as A slight offset with centrifugal load can cause the fiber plates to not properly release causing the jerk and stall of the bike as the engagement needs to be gradual and smooth When you are releasing the clutch lever in gear
