I found out that the starter relay and the main breaker are on the side of my oil reservoir. Then I found that both my hi/lo, horn and my start/kill toggles were both grounding out. I replaced both sides, soldered and heat shrunk tubed both. Then I found out that 88 was a transitional year where the starter and the solenoid were separate. Is there a way to run all of the all the other body systems separately instead of running all systems through the solenoid drawing the (EDIT) out of the battery while trying to start? The whole bike is drawing at the same time. Can all other systems be segragated from the solenoid? Bypassed maybe, separate toggle somewhere?
Please read this...
Please read this...
