Well after about a month of research and checking everything I can through the primary I cleaned and re-torqued with no success. The comp sprocket assembly looked good, the clutch basket looked good also. The chain is adjusted properly but I am still gettin a knock when off throttle. No problem at idle, plenty of power/torque while ridin and when I accelerate or pull the clutch in the knock disappears. It was mentioned in a previous reply to look for rotor wobble - I did notice that the rotor did wobble after the comp assemble was removed and I was able to remove the rotor with some effort but without a puller. Not sure what to check next. Any ideas? Thanks - 91 FXR
