J
Jack Klarich
Guest
If you were doing the base gasket would "you" remove the piston or would you keep it attached to the connecting rod? I'm trying to minimize the possibility of things going wrong to ensure a quality repair.
Thank you Jack
I leave the pistons on, just take care to wrap the pistons and do not turn the engine over with the jugs off, you can put rubber hoses on the cylinder studs while you work to avoid the pistons contacting them:s
