J
Jack Klarich
Guest
You sure you are not haviin an ignition failure, very common on V2 ignitions
Try rerouting and insulating your fuel line, you are percolating(boiling } your fuel before it gets to the carb
Double wall fuel line and wrap it in an insulator, keep it as far from the cylinder heat as you can JMO
I bet your ignition is causing the problem not the carb
Hard to do with a carb, it flows from the tank via gravity and float levelHave you done a fuel pressure test?
