Hoople
Account Removed
and if you put a 2010 engine in with a mm efi system, it will not run without the cam sensor, correct me if im wrong.
Your absolutely correct. I had forgot all about that. The late model Delphi is designed to work as a single fire ignition with no cam sensor. (anyone know how that can even be possible
But if your going to do it, a late model Delphi ECM would be the way to go. But I am pretty sure your going to need a new TSM, speedo and coil pack.
