I have just got done working on the bike and thought I would update before I grab a few hours of sleep. I pulled the tank and replaced the petcock with a non vac operated 1. Plugged the line from the voes T that went to the old petcock. I also flushed the tank and inspected the inside. I replaced all vacuum and fuel lines. Pulled the carb, cleaned and inspected it. Everything looked good. I tested the voes on the bench and it tested good. After I got everything put back together I checked for any intake leaks and found none. I also tested the voes again by letting the bike idle and I pulled the line from the carb. When I did this the idle decreased drastically so it seems it working. I also checked all the electrical connections while I had the tank off. I will give it a test ride this evening. Keeping my fingers crossed!
