tourbox
Senior Member
Re: Tools,Time frame,Procedures.
If you're taking your time I would say 4-5 hrs. in time. You can use a single edge razor blade for gasket removal. I use a Exacto type scraper with a flat blade about 3/8-1/2" wide. When you pull the cylinders up, once the piston skirt is out of the cylinder, place clean rags in the spigot holes to keep dirt,debris out of the crank shaft area. Leave them in there until you are ready to put the new base gaskets on.
Depending on your # of miles on the motor you may want to have the cylinders mic'ed for wear. I would use a ball hone and break the glaze in them at least. New rings will depend again on mileage and wear of the cylinders. Evo's are pretty tough. I've replaced rings on 70K mile motors and not needed boring. I will normally pour mineral spirits in the exh. ports & intake ports,individually, and check the valves for leaks while the heads are off.
As far as stock versus Adj. push rod the procedure is the same. Let them bleed down before going to the other cylinder.
tourbox
tourbox
