larryjmiller
Junior Member
Well, I checked it when I got home.  No more rattle when the front brake is applied.  I would recommend you check the allen head bolts that attach the exhaust to the tranny just below the chrome clutch housing.  Previously, I didn't notice the rattle when applying the front brake at idle until I had the other rattle from those two loose bolts.
It is possible that the rattle went away when the dealer made the ABS software change when I had the fluids changed at 5K miles. Although I can't tell the difference on stopping between the pre-software upgrade and how it stops now. The brakes still go into ABS mode at the slightest bump in the road when I apply the brakes. Makes me wonder if they actually did the software upgrade. When I asked them to do the upgrade, they looked at me like I was daft shrugged shoulders and said O.K. I suppose I could take it to another shop to check? Actually, I'm not letting them touch her unless the engine or tranny takes a dump which I doubt will happen these bikes are made like brick houses. I like the ABS and the way it works and I'm used to it engaging when breaking on a rough surface. At least I know it's working.
