gator508
Experienced Member
If that is 4 amps for the pair, you should have no problems.
If it's 4 each or 8 amps total (1/2 the capacity of a fused branch) think it through where your hooking them up. Look at the schematic to see what the fuse is already supporting and if it will support an additional 8 amps.
Hey Hoop,
Thanks! It's 4 amps for the pair. I stopped by the local HD shop yesterday and spoke with the guys, the concensus is to use the plug in on the harness leading to the headlight, located under the gas tank. I'm going to put this on hold until I get my service manual, ordered yesterday (not in stock of course). Also, the service manager advised me not to locate the lamps to the inside of the forks because of the possibility of bottoming out on the fender if I hit a bump. I debated with him that it seemed like a lot of fork compression would have to happen for that to occur, I may rethink the location, perhaps in front of the forks if they look good, you know they gotta look good too!
