stray dog
Junior Member
If you are installing an A/C with more air flow you will need to re-jet to add more fuel.
Not sure if this is your initial problem, but you will be running leaner than you will want to.
stray dog, I think that may be the issue, I installed the intake but i did not re-jet the carb. I checked my install and decided to take it down the road, once i got out on the street and the wind started blowing the bike was bogging down, so I think i may be getting more air than fuel? does that sound about right?
I should have been more clear. I just didn't want you to fix a possible install problem and go on your merry way without adding more fuel IF you have more air flow now with new A/C.
I agree with the other posts here that the black smoke indicates rich.
But why? If you went from stock A/C to more air flow you should be running lean.
Is exhaust still black? Or was it just once, maybe after you where twisting throttle around during A/C install?
I would follow the other posts here and double check install.
