J
Jack Klarich
Guest
You do not want the oil and moisture running back thru your intake and creating carbon build up, this is a bad thing and over time will cause your compression ratio to change a bit also, Jeff has posted Dolts way it is a good way, there are others, mine had a t fitting from the factory, I drilled a hole in my stock backing plate, ran the hose from the T fitting thru the hole ( nice tight fit) down between the front push rod tubes and down the frame under the floor board, I put a small engine fuel filter on the endHow does one go about that?
Why is it a bad thing?
