The K&N element is about $60-$80, a worthwhile long term investment! :s
$42 in Auto Zone. They have to order it for you.
Can pictures of the two different set's of rings be posted , stock air filter rings versus high quality free flow air filter rings with approximately the same amount of miles on each set. Would pictures with a micrometer be able to show the wear differences I would think if it were half, it would be noticable. Tim
I've never been a fan of high flow through air filters verses stock. The reason is that the filter can't flow more air without letting more grit/dust/whatever into the intake. It's just physics at work.
The only way I know that you can flow more air without letting in the grit is to somehow stack stock filters together so that you double the filtered area.
I've seen the rings out of engines that have had a steady diet of high flow filters and they are half the thickness of stock. Indicating that more grit is getting into the intake.
Sorry don't have them. I moved in the last two months from one province to another. The rings where out of a Japanese sports car with twin turbos, that had K&N filters. My neighbour at the time an auto mechanic,
( snowmobile/car racer/builder ) was showing me the difference in the stock verses used rings. He told me that this was a fairly common occurence in vehicles running high flow non stock air filters on the steet. I've often wished I'd taken a couple of the worn rings but didn't.
It was really hard to believe the difference in wear between a stock set out of a used engine and you wouldn't need a micrometer to see the difference. An ordinary ruler or tape measure would work, the wear was that noticeable. All he had to do was re-ring the engine to make it run.
I just added my 2 cents and experience for what its worth. Use what you wish but I'm a bit of a realist and if you where trying to flow water through a filter, the one with larger holes would flow more water. Therefore it would flow more air/grit. It only makes sense to me.
Not trying to cause problems, just posting a different point of view.
