dolt
Well-Known Member
I was toying with the idea of using the andrews tw 54 cams . They say they are for higher compression , with about the same character as the 37/57 . Using my 9 cc dome pistons and a .040 head gasket
Static comp : 10.2:1
Corected comp 9.29:1
Ccc :187.4 @1000
This would meen not having to shave the pistons . They say the power range is the same as the 37s , start pulling at 2200-5600
F.k.
P.s. What are peoples thoughts
That is as high as I would go with those cams. I don't think avoiding shaving the piston dome is a good reason for making a cam change. You would need to port the heads to take advantage of the 54 just as you would for the 57.
Sounds to me like you first need to settle on a budget for your project and start putting together a build plan to fit the budget. Time to fish or cut bait.:s
