Ok my bike is fi . Stock 88 set up .with a stage one I got a set of forged cp pistons 9 cc dome . I have another set of jugs to bore out for a 95 build with stock heads with low k . I'm trying to make it work with the less stress on the engine. Low lift cam .
I have a cobra 2 tuner on it .
How will this set up pull throughout the whole rpm range as compared to my stock set up 88 with stage one .
Sorry for being all over the place . I just want the engine to breath right . And been trying out the com p calculator
If I put a tw 50 on it with this set
OK, now I think I am getting the picture. You have the 3.885" bore CP pistons with a 9cc dome and a set of OEM cylinders that you will have bored to fit those pistons and you have a set of stock heads. You have a Cobra tuner but which one? Fi2000r, Fi2000r Closed Loop of Fi2000r Power Pro? None of the Cobra tuners are setup for dyno tuning and unless yours is the Power Pro, they are pretty much useless. You would benefit from a real fuel management system; a flash tuner like the Powervision or the TTS Mastertune and a dyno tune.
Your ultimate goal is more low and mid range power and you are not too concerned with high end of the rpm range; the priority is the low and midrange which is the right approach IMHO as that is where most of us ride.
Assuming head work is not in your plan, here is what I would do and I am sure you will get plenty of suggestions.
Have the machinist that is boring your cylinders also machine the piston dome down to 5-6cc and make a set of TW37 cams part of the plan. Replace the inner cam bearings with Torrington B-148 bearings and replace the cam chain tensioners with the CYCO units. Install the Baisley pressure relief valve spring in the cam plate for a little more low range oil pressure. Use a .030" Cometic MLS head gasket to tighten up the squish band and call it good.
As I mentioned, you really should consider putting the Cobra tuner on Ebay and purchasing a better tool; the tune will make all the difference. You cannot adjust timing with any of the Cobra units and some timing adjustments may be necessary for a proper tune.
This combination will pull hard but you will need headwork to get close to 100TQ/100HP; can't do it without head work but the bike will run much better than your 88"er.
If budget will allow head porting, we are talking about new springs that will accommodate higher lift cams; different ball game and more cames to choose from.
BTW, the TW50 duration of 248/250 will not perform well in the low and midrange; it's more of a higher rpm cam.:s
Another option to run the TW37 without machining the piston dome would be to run the cam retarded 4* and a .040" head gasket.
You haven't mentioned exhaust; what are you currently running?
The most important part of any build is the final tune; you really should consider replacing the Cobra system with something better. JMHO
