Well just returned from a local shop with some quotes.. Andrews Gear Drive setup w/new feuling lifters, push rods, 26G cam, and install kit + labor came in at $1497, S&S setup with same style lifters, 510Gear drive cam kit, and pushrods + labor (both estimated at 5hrs labor @ 80 an hr) $1493,******* now the chain drive S/E set up with a 26H andrews, and all the extras came in around $1150 out the door. They also had 95in cylinders and pistons that they would put in with the package for an $300 + another 1.5hrs of labor... So if i go with this on the high end lookin around 18-1900, low end around 15 from this dealer. Im gonna look up the parts list they gave me on the quote see if I can find cheaper ofcourse, (also quoted to dyno and tune it w/my PCIII in those prices) Thoughts on this anybody?
CHEAPER PARTS are not always the way to go..... I would stick with BRAND NAME ONLY.... Then you should have a quality BUILD....
ARE ALL THE KIT PARTS COMING WITH THE THE S/E set up? : oil pump, support plate, gears n chains for the NEW STYLE hydraulic tensioners?
your quote:
LIKE Chopper said YOU'LL PROBABLY WANT BIGGER CAMS..... HE SUGGESTED 211's and just what he post around here I would TRUST THAT STATEMENT from him..... you have a light bike
those cams like 26/37/ are MOSTLY for the BIGGER SLEDS and I used SS 570's in my TC but with the 95" and higher compression pistons @ 10.25/1...
YOU MIGHT THINK to go with the 95" for the money SOUNDS LIKE A GOOD DEAL depending on which pistons they use... and if bored or NEW cylinder barrels....
CHOPPER MAY HAVE MORE ON THAT....
REMEMBER the oil pump (KIT) and the support plate (KIT) is a MUST IN MY BOOK....... the hydraulic tensioners preferred BEFORE using the GEAR DRIVE
with the gear price and the SS510's they ARE NOT coming with the NEEDED parts like oil pump etc plate PARTS that come with the KIT for up-grade.....
If the S/E build comes with the oil pump and other KIT part LISTED on my part number...IT IS A GOOD DEAL.... but I SAY GO WITH 211's cams....
How many miles on your bike would suggest to me IF I would go with the 95" .... THAT is a good price given you BUT if you want to KEEP the 88" it will do just fine at that...
If you have 12,000 to 20,000 miles on bike NOW i would go for the 95" big bore at this time (just me) and FOR SURE THE 211's cams.
Later,,,,you can always up-grade to 95" if you want.... as all THAT consist of the UPPER END of which IS NOT TOUCHED FOR THE UP-GRADE ON THE CAM CHEST right now.... that being something ALL ON IT's OWN... and CAN be done latter....
