Welcome and maybe just in time.
I have a Baker 189-56 IPB and seal kit on order. Actually already arrived but I gave it to a brother because he had the same problem at the same time. I'm awaiting a new mainshaft from HD before I replace the bearing.
Here is the just in time part. I think I won't be able to use the Baker bearing and seal because it is made for '85-06. I asked the Baker guy if it would work on my 2007 FLHT, and he said yes, but that is with the original mainshaft. It is my understanding that all of the mainshafts are now shipping from HD at the '08 spec which is .008" smaller OD. They can do that because the mainshafts also come with a revised inner primary bearing inner race that is made to fit the smaller OD mainshaft.
At .008" difference, I don't think the Baker bearing will work and they don't have 2 different part numbers. I suppose that's HD's way of keeping you buying HD.
Anyway, re: suggestions for new parts to sell, that would be a great item. I'm replacing the mainshaft because as careful as I was in removing the race that had walked into the trans, the sealing surface got all buggered up. It also took way too much heat to get it off. I would have been much better off removing the mainshaft, then the race once it was out of the tranny case.
So if you find a bearing and also a seal that would work just like the Baker, that would probably be in demaind. The Baker is sealed (sort of) it has holes in it to accept the oil splash from the primary. My brother measured his '05 shaft at .9850 and the Baker bearing at .9860 making a .001" slip fit.
When the factory mainshaft comes in, I would need a bearing with the same oil splash lubrication, same OD & width, same internal bearing tolerances but an ID of 0.9852 which would give .001" tolerance on a 0.9780 shaft. The seal would have to have the same OD, same width and ride on the smaller shaft without leaking or having too much friction from being too tight.
That would be something you could probably sell lots of for all '08 & up HD's and any '06 & ups that have had mainshaft replacements.
I'll have a confirmation on mainshaft diameter once it arrives.
P.S. I'm in Chicagoland. Do you have a storefront?
At those prices, you could also do well selling a 5.875" primary drive locking tool
Sorry... off on the math. New shaft expected to be 0.977.
ID of bearing needed = 0.978
