mat 60
Senior Member
The only critical point is that it has to be HD branded water! You can get it at the dealer for $100.00 !
On my 09 Ultra, I could turn the heat management/rear cylinder shutoff on and off by rolling the throttle forward. When it is turned on, it only kicks in when the bike reaches a certain temp while idling. I kept mine on all the time, and I don't think the rear cylinder ever shut down. They say when it does, the sound changes, and you smell a scent that resembles marshmallows.Thanks for the replies but before the topic gets construed here, I am aware or all the tuner mix, parade fans, modes, synthetic oil etc.
My question is do you think the (Parade mode) Heat Management is worth even setting it up (in the ECM) since it only cools the rear cylinder, and of course your thighs which is a good reason I will admit, but by that time I would have probably turned my engine off.
Porter submitted a valid theory in that the rear one runs hotter than the front so this does shed some light in a functional direction. But I am just not sold that it's gonna help that much in keeping me engine any cooler than the default idle speed condition (not parade mode) that Smitty told me about (which also depends on leaving the throttle alone)
In other words I am debating if I even want to turn on HM (parade mode) .
Anyone know what the normal head temps are and when this heat management kicks in? Thanks.
