Oops, sorry Glider, I forgot to check the self-help.
The explanation in there is great, and makes a lot of sense.
So if a peson suspects that the compensator might be making noise I guess if would be smart to remove the outer chain cover and check it for torque?
Rod
You'll know if it is loose usually, it sounds like a rod is going bad in the engine at low speed, but yes it's a good idea to check it if you suspect it is the case.
Glider, we just want you to feel needed. :s
I Do!
