I have a Harley center stand on my 2007 Softail Standard (FXST). Very handy, use it often for cleaning, servicing, parking. It saves a lot of parking space. Easy to use. You lose no lean angle left or right and very little ground clearance. None at the center, just a little in front of the back wheel. Not something you would remove often; four bolts, a little hard to get to. It can be used as a jack, just put a block of wood on the floor, no need to change the adjustment on the legs. I was raised on British upright twins, they all had them. Would not be without one now.
