dieselguy65
Account Removed
I use HD primary fluid. But from alot of experience building automatic transmissions, there is nothing in our primary thatATF will harm one bit. the clutch pack, the sprockets or chain. all those same parts are used in automatic transmissions, in much more severe duty. the one variable that is different is immediately obvious, those transmissions use pressurized fluid to lube everything, our primaries are not.
All in all, use what works for you.
I had an elderly customer, who owned quite a number of over the road trucks. everyone he bought he drained all the fluids, and ran straight 40weight Delo400 in everything. engine, trans, rears, powersteering, etc.
never had a problem dong that. and that was in transmissions and rears that called for up to140W gear oils.
people use what people like.
