I have a couple of comments regarding this method for primary chain adjustment. There is a spring that exerts pressure on the wedge at all times. Why would it be necessary to use some scheme of adding inertia to it? OK, let's assume the spring is weak or something.
After accelerating to around 30 mph, it seems to me that it would be better to keep the throttle open a little while braking. Isn't the chain tightest on the bottom and loosest on the top when the engine is being driven by the rear wheel? We want the opposite here, loose on the bottom and tight on the top, as in acceleration. And why use the rear brake only? If the wedge is being driven forward by inertia using both brakes will assure a harder stop, "throwing" the wedge forward. Braking is a function of the brake caliper connecting the brake disk to the frame. The drive system is unaffected by how the bike is being stopped, front or rear brakes. Still, while there is forward motion and the clutch is engaged, the primary chain will be loose on the top and tight on the bottom.
I accelerated to about 30 mph as recommended in the original post but I kept enough throttle to ensure the bottom of the chain was loose. I then braked hard with both brakes. Worked just fine.
