Ok, I want to personally thank each and everyone of you who posted on my thread the try and help me. I will tell you guys that I accomplished the task and got my bike back running. It was the compression problem. I did have a intake leak that caused my back cylinder to keep from firing. I also found the trick to getting to those torx bolt heads as well. I went in and took the carb off and found that both bolts were lose...One was real bad and the other was tight but not tight enough. The one that was loose was so loose you could unscrew with your finger tips. So, instead I tightened the bolt up tight and it started running awesome. Actually it ran better than it has, I believe I have had the loose bolt for awhile now and it just got so loose it affected the running of the bike. Im gonna wait till riding season is over and then go in and replace all gaskets on it then. So, once again I can never ever thank you guys enough for the help you all have provided. May all of you be safe on the roads, keep riding!!!:bigsmiley11:
