This bike has had the air cleaner opened up and does have a V&H fuel pack installed.
before the EJK was installed.
My wife has a 2007 Heritage Softail and about everyother time she starts it it backfires thru the air cleaner. This bike has had the air cleaner opened up and does have a V&H fuel pack installed. I talked to them to see if there was something going on with the settings and they said "no". It also makes a terrible cluking noise when she starts it.
Any ideas what could be wrong?
A V&H fuel pack or an EJK? I don't understand which is installed.
pack I'm don't know much about the fuel pack, can I just unplug it and the bike will revert back to the original settings?
Thanks for the help guys, I will keep you posted.
Why don't you swap packs and see if the problem follows. JMHOHoople, my wife's Heritage has a V&H fuel pack on it and is the one in question. I have an EJK on my street glide. Sorry for the confusion...
Glider--I have not done a compression test or disconnected the fueler. I will have to find someone that has a tester to check the compression. I'm don't know much about the fuel pack, can I just unplug it and the bike will revert back to the original settings?
During engine cranking, spark advance is backed off but I am sure it is not to 0 degrees or TDC. Therefore any ABILITY to create primary backlash between the crank shaft and starter ring gear (bad spring-pack on compensator) will allow the engine to kick backward for 1 revolution on an unsuccessful engine start. That would absolutely create a backfire through the throttle body. I would bet the engine fires a few degrees before TDC just like it should,, and because of the bad spring stack in the compensator, the engine fires & just kicks back in the wrong direction. All the engine has to do is rotate 50 or so degrees backward and the intake valve will open..
You have a bad compensator that needs to be replaced regardless right?. Change it and see what happens.
I do not think the fuel pack does anything with spark timing. I believe it is only fuel injector changes. If it DOES change spark timing, you need to remove it as a test. But changing only the fuel amount should not make it backfire through throttle body.
Now if the fuel pack DOES change spark timing, then that is a different story.
