O.k., because I have 3 pins, I understand that I have dual primary sides. If I get .9 on each side independantly, that yields 1.8 together, which is below what I have been told. Tried to call the local mechanic to see what he said, but he couldn't make the time of day. I just don't have the shop manual yet, now I wish I did. I have been trying to find it on-line, but no luck yet.
Does anybody know the tolerance on the ohm readings? The secondary readings were right in spec, but the high side is a little low, what error tolerance could be expected. Also, my ohm meter doesn't have a zero adjustment, and it ream .2 to .3 when it should have read zero. So would that make my readings that much lower?
