Well, I put it back together, and gave it one more try for the gipper. I had my hopes up....it fired, ran for a second on the front cylinder I think, and then nothing. I was hoping it would throw a bad code, but no luck, they all came back clear. Bubbie I appreciate your patience, I just wish I knew a simple way to check the cpk before I go out and buy one. I read the literature on the post, but I can't make heads or tails of it.
Now I want full disclosure here.....
It ALL started a couple of weeks ago, at first I thought I had bad gas. It would cut out intermittently. I wondered if I was out of gas, switched to the reserve, and no luck, it was just cutting out on me. Not bad at first, but it wasn't running right. I put in a couple caps of gas additive, someone said I might have a little moisture in the tank. After the additive, boy, I could rev it up, and it sounded like a million bucks. Great right. Then it started running on and off with one cylinder. Replaced plugs and wires, and once again, it ran like the screaming eagle it was. Very shortly thereafter, it was running on one cylinder again.....only to be trumped by not running at all.
O.k., now you know what I know!!!
