bernhardz77
In agreement here -- it's a 09 - let the dealer check it out.
I considered that. But given that bad gas is not a MOCO fault, they would probably charge me a couple hours of labor to fix it.
Harley will usually shy away from selling the tools to customers ( Insecurity on their part). You have to find them in aftermarket suppliers.
Try one of the bigger HD dealers like Zanotti's. They have been known to sell tools over the internet.
https://www.zanottimotor.com/shopping/partLookUp.html
What part or Part number are you looking for?
I'll keep that in mind. Thanks.
It worked out that I got away without the tool. Was just trying to follow the service manual. I get myself in trouble enough with it. It's the one recommended in the service manual to take the top plate of the gas tank. Once I saw what the whole assembly looked like, I was able to prior it of and put it back on without the tool.
Here is the successful conclusion to my problem.
Emptied the tank and replaced the fuel filter and everything appears to be back to normal. The bike starts and runs fine again.
The only difference is that after the initial fuel pump stage, the light goes out and then shortly comes on again for a few seconds to go out again. Doesn't seem to be affecting the rideability however.
Attached is a picture of the old and a new few filter. The picture is slightly exaggerated because of the flash. Even though I don't have any experience on what it should look like, after only 7,000 mi on the bike, the old filter sure look awful dirty to me.
Thanks everybody for the suggestions and advice.
Bernhard
