The charging system is putting out 14v at idle. I checked the stator for shorted to ground and it is not. I have pulled the fuses one at a time and the only ones that eliminate the draw is the main fuse and the battery fuse. The fuses and fuse box are not corroded. I can pull all of the fuses except the main and battery and the draw is still there. I started unplugging connectors one at a time and when I unplugged the connector that plugs directly into the tach, the draw went from 1.0 to .6 . I left the tach plug disconnected and unplugged the connector that plugs directly into the speedo and the draw went from .6 to .1. This bike is a 2007 Low Rider with separate tach and speedo gauges mounted in a console on top of the gas tank. I have the wiring diagram and it shows the wire coming from the battery fuse going to the instrument connector, then to the individual connectors to the tach and speedo. I'm not sure why the tach and speedo have a direct connection to the battery fuse, but they do.
