NEWHD74FAN Experienced Member Retired Moderators Oct 24, 2009 #11 A fully charged battery is highly resistant to freezing and if the battery tender is on it, the charging process increases the chemical activity...heating the battery electrolyte slightly as a result.
S sodor Member Oct 24, 2009 #12 glider said: You can leave it in the bike as long as there is a tended attached. If you feel better about bringing it into a heated area, you can do that too. Click to expand... If connecting the battery tender to the bike (with pigtail) for the winter, is it best to remove the maxi fuse?
Drumrguy Account Removed Oct 24, 2009 #13 I just put the battery tender on my bike and leave it. No reason to remove any fuses.
gmurdock Active Member Oct 24, 2009 #14 When I lived up north I used a Battery Tender & a Jack to lift the bike. Make sure you lock the lift so if it does loose pressure it stays up.
