David, not meaning to interfere, but the stator is the fixed magnet array surrounding the engine driven rotor multiple coil assembly which ultimately make up the AC generator portion of the alternator charger. The alternating current (AC) is then converter to direct current (DC) by a rectifier bridge (diode array) and this is what ultimately charges your battery and powers the electrics.
Think of it as a motor or bicycle generator, the rotor shaft spins inside causes the moving coils to cut across a strong magnetic field producting alternating current.
In Harley's a "common" malady is for the magnets to break loose or the coils to insulation get overheated, scuffed, or regulator or rectifier short develops and "cooks" the insulation...the process repeats till the coil(s) and parts burn causing no electrical flow.
