BUBBIE
Well-Known Member
Hi folks. I'm a bit puzzled about my battery.
I have a Sporty with about 1700 on the clock. I keep it attached to an Optimate 4 tender when I'm not riding it - apart from a 3 week period about a month ago which it spent at my dealership having the 1200 conversion done I while I was away. I rode it very little up to this week because of bad weather and salted roads - I just did the 30-60 break in.
I've put two different battery chargers on to the battery and both are going into "Recovery" mode trying to restore it from being sulphonated. I took her out for a good ride with Hobbit and a few friends on Wednesday and she ran well but I have noticed a moment's hesitation before the engine turns over on pressing the start button.
I've checked the battery with a voltmeter and it's reading about 12.7-12.9.
It displays high 13s when the engine is running.
I don't know why the battery has gotten into such a poor state if the tenders are reading true. I don't know what else I could be doing to keep it in good order.:newsmile030:
Any thoughts or advice. Thanks guys.
I don't know if the 883 starter is LESS AMPS than a 1200 starter?????
On MY conversion to a 1200 and HIGHER COMPRESSION, MY starter would do about the same thing... IT would PUSH against the motor THEN kick over...
I don't think YOUR conversion is any different from mine.... I did mine on a 1995 in 96... I would ask if the starter is SMALLER on the amps... I had the impression on MY 1995 bike back then IT WAS LESS AMPS....
I kept the starter stock until it WAS a problem and THEN had a friend BEEF IT UP and rebuild it .... They have starter with the more power to turn over the BIGGER motor...
DID YOU WHIP THE MONSTER HOBBIT HAS???
I would always be ahead of Hobbit as I stay in the fast lane (right of center line) MIND THE GAP! over there.
