free website stats program battery volts at idle | Page 2 | Harley Davidson Forums
BTW a DMM (Digital Multi-Meter) has dropped in price considerably, an "inexpensive" Harbor Freight one this weekend costs $1.99 in the holiday brochure. Normally they are $9.99 and really can't beat the price of admission and worthy of being placed in an accessible area of your toolbox. A simple electronics/electrical primer:
Volts - connect + to positive (red), - to negative (black) across live terminals, in parallel, as it samples 1,000,000th or less of the electrical energy present without disturbing functions. It measures electric voltages up to a few hundred volts, but not the high tension secondary ignition voltages which can be 15-30kV (pressure if you use water in the hose analogy).
Ohms - resistance - measures electrical "restriction" in ohms...for testing non-powered electrical circuit paths for continuity ( 0 ohms = short) 1.999 = open or over resistance range, (hose diameter/restriction if you use water in the hose analogy).
Milli-Amps - "1,000ths of an Ampere used for measuring electrical charge volume or flow by breaking the circuit, in series (a shunt inside allows very little sampled proportional current to flow, but a bit inconvenient because you have to find a key place to break circuit (here is where breakout boxes are handy for terminal access). Observing + and - polarity AND keeping in mind that maximum scale only allows maximum reading of about 10 Amperes (not very much, so don't use this scale for measuring current any higher than simple light bulbs (use water flow volume - if you use water in hose analogy). For higher currents, it is more convenient to use a digital "Amp Clamp" which can be had for considerably more money.
Well its the stator again it failed a new one!!! and of course they the dealer didnt have one but they did use a used one and it worked so they ordered a new one. I will get the part Number to share. thanks for every ones Input rich.
Looking forward to his opinion,thanks for sharing.
well here it is they used a 07 parts on my 06 wg and they worked.
now i have 14.24 volts at idle and at 3000 RPM 14.32 and heres how they did it. If any body wants to the complete RO JUST PM ME. Thanks for everyones support.
1 STATOR ASSY 3 PHASE 38 AMP p/n 30017-01A
1 ROTOR & SPRING COVER ASSY P/N 40356-07
