JohnnyBiker2
I talked with my Redline rep. after quizzing him on the oil temperature I had on the 2006 1200 sport R... always under 200* running 20/50 Redline full synthetic.
I was never over 200* even after a run in Az. 95* day... He said I would NOT need the oil cooler on my bike.. He would prefer the oil to run Hotter than it was showing in my sporty... He said that the oil should get Hot enough to cook out the moisture that accumalates in the engine... Too Cool of oil Is Not such a good thing..
I know of a few bikes that have built-up Crud in the Upper side oil tank(sludge) over a long time from moisture Not boiling off... That is something that caused me NOT to install the Jagg on the sporty After buying it... Now I have the Jagg for my 09 FLHR that Needs All the Help it can get in the Cooling process...
Hey there Bubbie, you are right that the little older bikes do seem to run a little cooler, go figure. I am not so sure that I agree with you 100% about letting your oil get so hot that it burns water and other contams. After a certain temp the poil looses its lubricating properties as well. If I see oil temp creep up to 250, then I am a little concerned with what is happening, especially on a smaller engine.
It is like you read my mind, the Jagg is the cooler that I have been considering, the cool thing about the particular cooler that I am looking at is that there is a manual thermostat to where you can adjust for on those cooler days, cold oil is not good for an engine either.
