ddickerson
No doubt , thanks to the help from this sight .Great job sticking to it. You know her a little better now.![]()
dolt I'd gladly buy all contributors on this thread a six pack for the help, if ever in Louisiana look me up!
Good job, glad your back in the saddle. I'm still scratching my head about the bubbling in the tank tho. :bigsmiley21:
Could the pressure regulator in the tank be the culprit, bypassing fuel? I know I am not suppose to have a regulator in the tank, but it is the same as the 2002 diagram. There is a port on the regulator like either a vacuum line would hook up or would return back into tank. Possibly a service bulletin for this year that changed the fuel pump assembly!!
Rode 60 miles today slight stutter now and then, still burning the sea foam out of the tank. At least I am able to ride!
I was thinking the return line with the MM system was the reason for the tank bubbles. The Delphi system doesn't have a return line.
You definitely have a hodge podge of parts there tho and may not be totally out of the woods as far as a good running bike.
I would run the seafoam for a few more tanks yet and see.
Good luck and check back and let us know!
