The self help area of the site seems to be missing a lot of the carb stuff but if you look at this one it has a lot of additional info on the cv carb
Harley Davidson Community
Have you looked in the tank? You sure the petcock isnt clogged with debris or rust. Remove petcock or remove the tank and flush clean. Checked for intake leaks?
Your jetting is fine.
ALSO, did you get the little squirter arm on the side of the carb in-place correctly??? that gives the excellerator pump a Squirt of raw gas when twisting the throttle..
Bike Not running to perform this test:
Take off the airfilter and look to see When You twist the throttle all the way open,,,,Do you see a big squirt of raw fuel hitting slide of the carb????
Should look like a Full squirt gun blast coming into the carb fron the little brass squirter standing up tube in front of the slide.
IF not something is wrong there ALSO.
I still think you have a Big air leak, the intake can be checked using a propane tank with nosel UN-LIT.or brake or carb clearner with a little plastic nozzle to spray Right on the carb gasket then the manifold gaskets on the intake. when running IF there is a leak the idle will pick up faster because of the spraying of burnable substance sucking into the leaking gasket...
