I'll have to agree with Doc and Ultra on this one.
Like I said in my earlier post, big heavy bikes have a tendency to do this.
I should have been more detailed in my earlier response.
Also in my earlier post I was referring to a bike that did have a problem that was outside of what I would consider acceptable and so did the service manager when he came back white as a ghost after he duplicated the problem with him riding it. It was eventually traced to a cracked weld on the swingarm that was hidden by the powdercoat.
This was a really isolated incident and I can't stress that enough. The weld and tubing were fine. The crack was probably caused by a normal Oklahoma pothole or what none Okie's call a un-negotiable obstacle.
I have no problem taking any turn 5 or 10mph over the posted limit. It's only when I really push it that I get a tail wag. Sometimes it happens when I unload the chassis such as a dip in the road but it always settles right down.
Big difference between a little tail wag and a high speed wobble!
I've never had any Harley shake it's head. Harleys are rock steady as far as that phenomenom is concerned.
Get on a metric bike and run it up to 75mph, take your hands off the bars and slap the grip. That'll show you the difference. You'll pray for a little tail wag after you relax enough to be able to walk again.
The devices that are available will help, but if you're gonna ride baggers that can push 1200-1300lbs two up and loaded you're gonna have to put up with some little quirks that you won't experience on a 500lb bike.
I do think that unexperienced riders handle these things the wrong way.
Personally, I think the worst thing you can do is whack the throttle closed and get on the brake. When you load the front end with a bunch of weight in the middle of a turn you can run into some real problems such as washing out the front end or front tire chatter.
Harley baggers are made for one thing and that's eating up asphalt at high speed. No bike on the planet does this better!
They're not made for high speed cornering but they do that pretty well too if you know your limits.
Hell, my wife is so used to it that she says likes it.
Go Figure:s
Geno
