C critter45 Member May 17, 2011 #11 where can i run a wire to make my cig lighter work. without causeing any problems
G glider Veteran Member May 17, 2011 #12 I would run a separate wire with a fuse inline to the battery + being the lighter draws a bit so you will not end up with the same scenario with another circuit.
J Jack Klarich Guest May 17, 2011 #13 Good deal you got it sorted out, never hook up to the coil let alone the ignition for a lighter, separate fused circuit from the battery:s
C critter45 Member May 17, 2011 #14 sportster exhaust any one know the best and cheapest place to buy new exhaust for my 02 sportster 1200
J Jack Klarich Guest May 17, 2011 #15 Re: sportster exhaust critter45 said: any one know the best and cheapest place to buy new exhaust for my 02 sportster 1200 Click to expand... Depends on what you are looking for If you want cheap and loud try Cycle Shack mufflers, drag pipes and heat shields
